  3. difference between capacitors of libraries
  • Subscribers 133
  • Views 18165
archive over 18 years ago
Hi everybody.
There is a difference between the Cell Capacitor, the cell mimcap  of Cmosp18 library and Cell cap of AnalogLib ?
There is a condition to use one rather than another??
Originally posted in cdnusers.org by isazul
    The "cap" in analogLib is a generic capacitor - usually ideal (depending on the parameters yuu provide) - a direct interface to spectre's built-in capacitor.
    The capacitors in Cmosp18 are presumably models of real capacitors for whatever process you're using. These will most likely model non-idealities of the process, and probably have a layout representation too (analogLib can't have physical representations because it is not technology dependent).
    Originally posted in cdnusers.org by adbeckett
