  3. Encounter -> OA -> Virtuoso conversion problem
  • Views 4435
baumanets
baumanets over 12 years ago
Hello.
I load to OA library LEF
cmos090 - PDK Library
   lefin -lef ../../../../common/SOC_DATA/lef/CORE90LPHVT.lef -lib
techliboa3 -techRefs cmos090
    lefin -lef ../../../../common/SOC_DATA/lef/CLOCK90LPHVT.lef -lib
  lefin -lef
../../../../common/SOC_DATA/lef/IO90LPHVT_1V8_50A_7M2T_soc.lef -lib
    lefin -lef
../../../../common/SOC_DATA/lef/IO90LPHVT_FILLERCUT_50A_7M2T_soc.lef
-lib techliboa3 -techRefs cmos090
  lefin -lef ../../../../common/SOC_DATA/lef/BG1V2_25_C90LP.lef -lib
   lefin -lef ../../../../common/SOC_DATA/lef/DC_LN_3V3TO1V8_100_soc.lef
   lefin -lef ../../../../common/SOC_DATA/lef/PLL_PG_800x_soc.lef -lib
     lefin -lef ../../../../common/SOC_DATA/lef/PR90M7.lef -lib
      lefin -lef ../../lef/rings_BE.lef -lib techliboa3 -techRefs cmos090
   lefin -lef
../../../../common/SOC_DATA/lef/IO90LPHVT_BASIC_50A_7M2T.lef -lib
Then I save encounter project to OA database techliboa3
If I open  TOP_LEVEL cell i see Library in cells "FEOAreflib"
I want to refs via to PDK tech library and cells to STD/IO etc. library, but encounter save TOP_LEVEL with refs to  FEOAreflib
I tried to remaster cells, but it takes very long time.
How save/convert Encounter project to OA DB with refs to PDK, STD/IO?
  • Quek
    Quek over 12 years ago
    Hi baumanets
    Such problems should not exist if your Encounter design uses OA inputs. If you are trying to convert a LEF-based design to OA format, perhaps you can refer to COS article 11736956 to see if it helps?
    Best regards
    Quek
  • Quek
    Hi baumanets
    By the way, this question should be posted in the "Custom IC" forum and not this SKILL forum.
    Best regards
    Quek
    Quek,
    I moved this to the correct forum. Thanks for pointing it out (and answering a whole bunch of questions!)
  • Quek
    Hi Andrew
    Thanks. : )
    Best regards
    Quek
  • baumanets
     Yes, I am trying to convert a LEF-based design to OA format.
    Comand
    lefin -lib gpdk090 -lef LEF/gsclib090_tech.lef  -overwrite -log LOG_DIR/tech.lefin
    creates new tech library.
    I read
    Solution ID:11736956
    and
    Solution ID:20217208
    But I want to attach design to the existing pdk library (not new tech library, created by lefin)
    The comand
    lefin -lib gsclib090 -lef LEF/gsclib090_macro.lef -overwrite -log LOG_DIR/macro.lefin -view abstract -techRefs gpdk090
    creates new std library with abstract view.
    But I want to attach cells to my existing std, io, etc libraries.
  • Alex Soyer
    Alex Soyer over 12 years ago
    You need first to create the library that you would like to import the LEF into.
    Please make sure at the library creation if you want to attach (only one library containing all the technology information) or to reference (if you want to use the incremental techfile capability).
    After you run the lefin command with target library the newly created one.
    Can you please clarify what you mean by:" But I want to attach cells to my existing std, io, etc libraries." ?
    I assume that you want your design to reference the newly created library.
    In that case you need to run a remaster instances into the view.
    The best would be to save from EDI :
    Converting the EDI System Database to OpenAccess Database
    Run the following commands to convert the EDI System database to OpenAccess database:
    1. Run restoreDesign fe.enc.dat cellname
    2. Run set init_lef_file ""
    3. Run set init_oa_ref_lib " techLib"
      Other OpenAccess design reference libraries can also be appended. The first one should be the technology library.
    4. Run  set init_oa_abstract_view   "abstract"
    5. Run  set init_oa_layout_view   "layout"
    6. Run  saveDesign   -cellview   {designLib topCellName viewName}
    Alex
