  3. Display Instance name in Layout
  • Views 20827
KishanCh
KishanCh over 12 years ago
 Hello Andrew,
 Is there a way to display Instance name along with cell name for layout instances in partial view?
Kishan
    Kishan,
    Options->Display and then there's "Show Name Of" which can be set to "instance", "master", or "both". So "both" is what you want.
  • KishanCh
    Thanks Andrew..
  • sypetre
    sypetre over 6 years ago in reply to Andrew Beckett
    the names of drain, gate ... of my transistors disappeared and I am not able to get it back. All objects are well selected and set to visible ...
    Do you have an idea ?
    Sylvain.
    Andrew Beckett over 6 years ago in reply to sypetre
    A picture would help. Perhaps in ADE you need to do Results->Annotate->Design Defaults?
  • sypetre
    Thanks for the answer Andrew.
    The problem was that I opened the layout from the library manager. I fixed this issue by launching my layout from my schematic.
    Best regards,
    Sylvain.
    Hi Sylvain,
    I can't really see why that would matter, but at least you have a way forward.
