  3. Digital vector file
  • Views 17592
Digital vector file
ahmed osama
ahmed osama over 12 years ago
 Hey All
I am facing a problem in simulating 64 bus comparator , i am using spectre simulation , but when i make a simulation spectre divide bus in to signals a[63],a[62],.... , how i could collect them in one signal ?
i found something called digital vector file , anyone use this script , i want a help in making .vec file and run it on spectre simulator
    Andrew Beckett over 12 years ago +1
    Did you try reading the documentation? There's a chapter on "Digital Vector File Format" in the UltraSim User Guide at <MMSIMinstDir>/doc/UltraSim_User/UltraSim_User.pdf Regards, Andrew.
