  3. error while plotting current with spectre
  • Subscribers 133
  • Views 17740
archive over 18 years ago
hi,
I can not display current when simulating with spectre. I have an error like:
- Error Expression  IS("/M1/directoryAddress/ ) did not evaluate to a waveform.
but when i simulate the same circuit with SpectreS i display the current without problem.
How can  solve this problem in spectre
Originally posted in cdnusers.org by isazul
    IS is for ploting dc sweep. Are you running a dc sweep? If not, use IT or IF or
    whatever analysis you are running.
    If you are running a dc sweep, open the Results Browser and see how spectre saved
    the data. Try to create your calculator expression from there.
    Originally posted in cdnusers.org by EricCDN
    hi Eric
    when I use the result browser I succeed in plotting the DC current. The displayed name with result browser is "I4.M5:s" and with a direct plot it's "I4/M5/S" to refer to the source of the MOS M5 of the instance I4.
    how Is it possible to change the format "I4/M5/S" in order to be able to plot dc-sweep current simulation directly??
    Thanks..
    I have no trouble plotting current with direct plot.
    Are you using analogLib parts or your own library? If your own library, is the spectre simInfo set up correctly?
    in both case, there is plotting problem only for current.I think spectre is well set up. By simInfo correectly set Up do you mean "importing spectre from spectreS"?
    Yes, that's what I mean. Make sure the simInfo is similar to the simInfo on the nmos4 in analogLib
