  3. can't plot waveform while simulating in cadence virtuoso...
  • Replies 11
  • Views 21677
can't plot waveform while simulating in cadence virtuoso via spectre
leangineer
leangineer over 12 years ago
Hello!
I can't plot waveform while simulating in cadence virtuoso IC 6.1.5 via spectre.
When I initiate Netlist and Run (green button), these are the results:
Delete psf data in /home/eda/simulation/R_div/spectre/schematic/psf.
generate netlist...
Begin Incremental Netlisting Apr 6 23:23:36 2014
End netlisting Apr 6 23:23:36 2014
The netlist is up to date.
Time taken to compare the design with netlist: 0.0s
...successful.
compose simulator input file...
...successful.
start simulator if needed...
...successful.
simulate...
INFO (ADE-3071): Simulation completed successfully.
reading simulation data...
...successful.
net /in selected but not highlighted
net /out selected but not highlighted
---Any solutions? Thank you!
    Andrew Beckett over 7 years ago in reply to Mehdi Nasr
    Hi Medhi,
    The first (pinned) post in each forum is a set of guidelines for posting in the forum. This asks you not to post on the end of old threads (I’ll let you off this time) but more importantly asks you to provide the software versions you’re using.
    I’d need to know the Virtuoso subversion you’re using (Help->About in any window will tell you) and also the spectre version (this will be in the spectre.out simulation log that appears when you run spectre). Also, if you look in ADE at the Outputs->Save All form at the bottom, does it show the output format you have selected?
