  3. PSPICE model
  • Views 15588
PSPICE model
afuno
afuno over 12 years ago
I'm using Virtuoso 6.1.5.
I downloaded a PSPICE model from a supplier.
However, it doesn't work because of syntax.
Could you give some advices to solve my problem?
(For the confidential reason, I have masked the specific number)
simulator lang=spice
.SUBCKT  model  20  10  30 Rg      10   1    1 M1      2    1    3    3    DMOS    L=XX   W=XX .MODEL DMOS NMOS (VTO={X.XX*{-X.XXX*TEMP+X.XXX}}  KP={XX.X*{X.XXXX*TEMP+X.XXXX}} + THETA=X.XXX  VMAX=X.XXX  LEVEL=3)  Cgs     1    3    XXXp Rd      20   4    XXm      TC=X.XXXX Dds     3    4    DDS .MODEL     DDS    D(BV={XXX*{X.XXXX*TEMP+X.XXX}}  M=X.X    CJO=XXXp    VJ=X.X) Dbody   3    20   DBODY .MODEL   DBODY    D(IS=X.X   N=X   RS=Xm   EG=X   TT=XX) Ra      4    2    XX       TC=XXX Rs      3    5    XXX     Ls      5    30   XXX M2      1    8    6    6   INTER E2      8    6    4    1    2 .MODEL   INTER    NMOS(VTO=X     KP=XX     LEVEL=1) Cgdmax  7    4   XXXX Rcgd    7    4    XXX Dgd     6    4    DGD Rdgd    4    6    XXXX .MODEL     DGD    D(M=XXX     CJO=XXXX     VJ=XXX) M3      7    9    1    1   INTER E3      9    1    4    1   -2
.ENDS model
simulator lang=spectre
    See my response here: /forums/p/28236/1330382.aspx#1330382
