  3. debug current flows
  • Views 15464
debug current flows
keiichim
keiichim over 12 years ago
 Is there a way in spectre of AMS-designer to debug current flow?   Currently I'm using AMS interactive with simvision to debug from the top level.  If I see an unexpected current value from a top port, I would like to follow down the hierarchy to see what the major contributor up the hierarchy.  Are there any ways to do this?  Currently I pause the simvision, probe port flows down the hierarchy.  It's a bit cumbersome and I'd like to see a way to do it more elegantly. Thanks!
  • PaulCollins
    PaulCollins over 12 years ago
    Bump!
    I would also like to know. if this is possible with voltages, like so:
    set measvoltage #$TB_NAME.Portname
     then how can you access currents using a similar approach and assigning it to a variable.
    adding -flow does not work in the same way it works for probe.
    To the original poster's question, I don't think you can do this any way other than what you've done.
    For Paul's question, you need to use the value command rather than the # shortcut. So:
    set meascurrent [value -flow  PLL_160MHZ_sim.I3.IEXT_25u]
    The "-flow" is important here.
  • PaulCollins
    Thank you Andrew for the quick reponse,
    I will give that a try.
     Paul
