  3. Re:Annotate DC Operating point
  • Views 1947
Suresh P
Suresh P over 12 years ago
After running DC simulatin, when i do Results-> Annotate-> DC operating point it is showing the following warning
*Error* eval:undefined function
Pls help me to fix this
  • Quek
    Quek over 12 years ago
    Hi Suresh
    It would be great if you can let us know the exact version of the software which you are using. Please see the forum guidelines. You can go to "CIW: Tools->CDF->Edit" and check the "Interpreted Labels" section for the devices to see if the settings are ok.
    Best regards
    Quek
    I suspect this may be something in an opParamExprList entry in the CDF. If this doesn't show up on the Edit CDF form, if using an IC61X version, set the CDF type to Base for the component in question, and use the "CDF Dump" button to dump to a file. Or in any version use:
    cdfDump("yourLibName" "yourCell.cdf" ?cell "yourCell")
    and then post the resulting file ("yourCell.cdf") here.
  • Suresh P
    Thanks for the reply and the problem was solved now
