  3. assura LVS error --- No property
  • Views 1341
zczc99
zczc99 over 12 years ago
I am using assura for LVS check, the version is :  4.1_USR1_HF12_514
There are errors like:
Error (AVLVSDF-10007) :No property 'modelName'  is specified for cell 'pmos'.  specify property 'modelname' in CDF for 'auCdl' simulator
Error (AVLVSDF-10007) :No property 'modelName'  is specified for cell 'nmos'.  specify property 'modelname' in CDF for 'auCdl' simulator
But in CDF editor, I can find the modelname for both pmos and nmos. What is wrong, how can I solve this problem?
 Any advice is appreciated! Thank you.
  • Quek
    Quek over 12 years ago
    Hi zczc99
    Would you please try the following to see if it works?
    a. Go to CDF form for nmos and pmos and set the mode to "Base"
    b. Press "simInfo" button
    c. Add the following parameter mapping for auCdl:
    modelName SpectreModelName
    Best regards
    Quek
