  3. How to override parameters in the same block - ADEXL Global...
  • Views 4259
How to override parameters in the same block - ADEXL Global Variables
WMACH
WMACH over 12 years ago
Hello, I was wondering if you could help with the following issue:
The vendor's provided model file has a definition for a parameter (param1) which I would like to override. Both definitions would happen in the same "block" (same level). The way I'm trying to do this, with no success, is as follows:
A. Define a Global Variable in ADEXL as param1 = 0
B. The netlist (input.scs) generated is:
parameters param1 = 0
include "vendor's model file"  (In this model file a definition of param1 = 1 exists)
C. A warning in "spectre.out" is created:
 WARNING (SFE-2297): "vendor's model file": Parameter `param1' is already defined in the same block, previous definition is ignored.
It seems to me that I would need to revert the order of declaration as described in B.,but I don't know how to do it.
Would there another way to do what I'm trying to do?
Wil
  • Tom Volden
    Tom Volden over 12 years ago
    Hi Wil,
    You could try having the model file definitions appear before the parameters statement using the following .cdsenv variable:
    spectre.envOpts    netlistModelFileFirst   boolean  t
    or the equivalent in the .cdsinit file:
    envSetVal("spectre.envOpts" "netlistModelFileFirst" 'boolean t)
    Since netlisting happens in the ICRP process in ADE XL you will need to have this in the .cdsenv or .cdsinit file rather than entering it in the CIW.
    TOM
  • WMACH
    Thanks TOM, I will give it a try. -- Wil
  • WMACH
    Hi TOM,
    Just a follow-up, I did confirm that what you suggested above works nicely.
    Wil
