  3. How to reversely perform transient simulation?
  • Replies 9
  • Views 17489
Baiyuzhong
Baiyuzhong over 12 years ago
     I have a circuit with serveral transistors and wish to perform backward transient simulation, i.e., for a given final condition for each node, wish to guess/calculte the initial node voltage. Seems that in cadence transient simulation setup it doesn't allow the inital time to be less than the final time. So I'm wondering  anybody know how to do this? Thank you very much.
  • FormerMember
    FormerMember over 12 years ago
     Dear Baiyuzhong,
     >  wish to perform backward transient simulation, i.e., for a given final condition for each node,
    What is the motivation for performing a "backwards transient simulation"? I can't imagine why this is needed. There cannot be a unique solution without knowing some starting point. I have not heard of such a thing.
    Maybe he's invented a time machine?
    I've never heard of anyone wanting to do this before.
  • Tom Volden
    Tom Volden over 12 years ago
    The time stepping algorithms used for transient simulation always run forward in time.  I don't think there is a way to do what you propose.
  • Baiyuzhong
    smlogan said:
     Dear Baiyuzhong,
     Thanks for the quick reply. I want to explore how the initial condition evolve in time domain (whether any initial condition can converge to the same final).   Now the starting point is the stabe state and I actually don't want unique solution, I want it to be every possible initial condition.
  • Baiyuzhong
     Wow, I wish I could invent a time machine. That would be great!!!
    Here I just want to explore the convergence problem. To see whether any initial condition can converge to the same final.
  • Baiyuzhong
    You're right.  The transient simulation is basically solving ODE eqations, right? Then if somehow I can change the time variable  't' to '-t', it would be reversely solving the ODE equations (In fact, I tried to use matlab to solve ODE like this, it works). The things I don't know how to access the the ODE model and change the variable.
    Well, this is not possible, and I'm sure we wouldn't implement such a capability. For a start, there are too many assumptions that time goes forward, and some components are not modelled via ODE (eg delays, nport, transmission lines). I suspect with a huge amount of work it might be feasible but one big problem would be how you would solve the end point that you are starting from. Right now we can do that with a dc operating point which works by finding a solution with all the capacitances and inductances removed, but for an arbitrary end point that you'd want to go backwards from, you'd have to solve for potentially part charged capacitances and inductances without being able to work out how you got there. I think the elements involving delay would be a problem too.
    Regardless of this, I seriously doubt it would help you understand anything about convergence.
    So no, you can't do this and there is no prospect of this being implemented.
  • Baiyuzhong
    Thanks for your reply. I still got some questions about this.
    (1) what if all the components in the circuit that I'm interested can be modeled by ODE, I think it can be solved reversely by setting 't' to '-t' or setting all capacitances to be minus. Right?
    (2) for the end point, I can use DC simulation to obtain the final state and slightly change this final state to get certain number of end points, (so it's not arbitrary). Then start the backwards from these end points; in each backward, when any node voltage reaches 'vdd' or 'gnd', terminate  and get a solution. Finally obeserve how these solutions distribute.
    (3) I didn't quite understand  the statement "you'd have to solve for potentially part charged capacitances and inductances without being able to work out how you got there“. What did you mean by "potentially part charged capacitances and inductances"
    I already explained that there is no way of doing this, so I'm not quite sure what the point of persisting with these questions is. If you are starting from a DC operating point (my assumption was that you wanted to do this from some arbitrary condition), I fail to see how doing a reverse time simulation would tell you anything useful, even if it was possible, which it isn't.
