  3. Delay calculation for full adder circuit
  • Replies 7
  • Views 21316
KISHORE085
KISHORE085 over 12 years ago
Hi all,
i've designed a full adder circuit in cadence virtuoso. i wanted to know how to calculate over all delay. i know how to calculate delay between two signals using calculator tool. But dont know to calculate over all delay. Please help.. .
    Please help explain what you mean by "over all delay". I don't understand your question, since you already know how to calculate delay between two signals. What's the difference in what you're asking?
    Kind Regards,
  • KISHORE085
    I mean the total time taken by the circuit to give output after providing input..
  • KISHORE085
    hi, "over all delay" I mean the total time taken by the circuit to give output after providing input.
    So why can't you use the delay function to do that?
  • KISHORE085
    Using delay function, it is possible to calculate delay between any two signals. But in my circuit, i have 3inputs and 2outputs. How to do in this? If i had 1input and 1output i could've calculated using delay function.
    This of course depends on how you are varying the inputs. If the input stimuli is under your control, then you know when it changes and so you probably don't even need to use the delay() function. You could use the cross function to look for a crossing event in a particular window of the input or output. Then the "overall delay" would be:
    max(crossOut1 crossOut2)-min(crossIn1 crossIn2 crossIn3)
    where each cross above is a cross expression on that output or input.
    Something like that.
  • KISHORE085
    ok sir. Thanks a lot for replying. I'll check the cross function and get back to you.. Thanks again..
