  3. HELP!!! insert gpdk180 into IC615
  • Replies 7
  • Views 27193
hTmTech
hTmTech over 12 years ago
how to add library gpdk180 into cadence virtuoso IC615  ??
thanks
    Assuming you have gpdk180 installed somewhere, just add:
      INCLUDE /path/to/gpdk180_v3.3/cds.lib.oa22
    into your cds.lib. Or if you only want the gpdk180 library itself, you could add this to your cds.lib:
      DEFINE gpdk180 /path/to/gpdk180_v3.3/libs.oa22/gpdk180
  • hTmTech
    I have a folder gpdk180 but I did not find this path  "" /path/to/gpdk180_v3.3/cds.lib.oa22 ""
    plz send me this library in my gmail acount
    Two issues - first of all, I don't know what your gmail account is, but more importantly there's a click-through license agreement to download it. So I wouldn't do that anyway.
    You can access it via http://support.cadence.com - go to Resources->Other Resources->Generic Process Design Kits. The direct link is:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=wp;q=ProductInformation/GPDK/GPDK.htm
    Maybe you have an old version with only CDB (IC5141) libraries?
    The "/path/to" bit is just an example of where it might be on your system.
  • hTmTech
    This is the same way as I did for download
    and I had this library gpdk180  but I found the problem to integrate in IC615
    the library work very well with IC5
    thanks
    Regards ;
  • Tom Volden
    Tom Volden over 12 years ago
    The gpdk180 will have both CDB (IC5) and OA (IC61) versions of the library.  You need to point to the OA version in your cds.lib.  I'm not immediately seeing gpdk180 on my system, but if I recall correctly they have a parallel directory structure so you'll see something like gpdk180/libs.oa and gpdk180/libs.cdb or gpdk180/build.oa and gpdk/build.cdb.  Your cds.lib will need to point to the oa version for IC615 so it should have a statement like:
     INCLUDE <path_to_gpdk180>/build.oa/cds.lib
    or
    DEFINE gdpk180 <path_to_gpdk180/build.oa/libs/gpdk180
  • Tawna
    Tawna over 12 years ago
    You can also look here for step by step instructions on how to download the gpdk180:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/spectreRF/spectreRF13.1.1/AppA.html
    best regards,
    Tawna
  • hTmTech
    thank you very much Mr. Tom Volden
    problem is solved with point to the .oa version
    thank you everybody
