  3. Abstract Generator : tech file and origin in LEF file
  • Views 18481
samung
samung over 12 years ago
Hello !!
I am generating a LEF view with Abstract Generator Tool, from a layout.oa, for a simple inverter cell (up to M1 layer).
I have the following lines in the generated LEF view :
MACRO test_iv_LayoutToCEL
  CLASS CORE ;
  ORIGIN 0.18 0.24 ;
  FOREIGN test_iv_LayoutToCEL -0.18 -0.24 ;
Actually, I would like to have ORIGIN 0 0 ;
How should I do ? Do I have to  add some lines in the tech file or to specify something in the Abstract generator ?
Screenshot in attachment.
Thanks !!
P.
StdCell_origin_layout_to_LEF.pdf
  • ColinSutlieff
    ColinSutlieff over 12 years ago
     Hi Samung,
    you can change the data in Virtuoso by  clicking edit->advanced->move origin.
    But, if you are converting any place-and-route data to other environments (where the data uses a different origin) your layout will get messed up.
    Remember that LEF/DEF based tools always use the lower-left as an origin (independent of orientation) so you shouldn't need to change anything.
  • samung
    Ah ok, actually, the PRBoundary layer exists already in my layout.oa (as an Object). So I said to Abstract Generator not to generate any boundary, because it was already existing.
    LEF result is GOOD :
     VERSION 5.6 ;
    BUSBITCHARS "[" ;
    DIVIDERCHAR "/" ;
      CLASS CORE ;
      ORIGIN 0 0 ;
      FOREIGN test_iv_LayoutToCEL 0 0 ;
      SIZE 0.36 BY 1.96 ;
      SYMMETRY X Y ;
      SITE core ;
      PIN A
    Thanks !!
    Pierre
