  3. VerilogA definitions from ADE-XL
  • Views 14937
daasboe
daasboe over 12 years ago
I would like to be able to make a VerilogA `define in Cadence ADE-XL environment. Is that possible to do? The reason for this is that I want to have the same VerilogA module and symbol, and change sequence depending on what simulation I am running (`include different files). Is there another way to do it?
BR,
Daniel
    Daniel,
    From "spectre -h":
         -va,define MACRO[=value]
                      Defines a macro with higher priority than the one defined in Verilog-A files.
    So you should be able to add "-va,define MACRO=value" in the usrCmdLineOption field in Setup->Environment in the test editor.
    Maybe that does what you want?
