  3. ocnxlRun never returns as some splits are hung forever
  • Views 15316
Tajinder
Tajinder over 12 years ago
I am using ocean script to launch ADEXL simulations in netbatch (pool of machines). After setting up the testbench, I use ocnxlRun to launch the simulation. Several hunderd splits get launched in parallel. Due to machine or other issues, it so happens that one of the splits never returns. Therefore the entire job just waits forever and we never get the result back. As a workaround, I typically ssh to the machine running the hung split and kill virtuoso process. It then restarts the split from scratch and job finishes. We tend to loose significant time on this and lately we are seeing more than one splits that are hung. Do you have suggestion on how to deal with this situation? Do you think specifying runtimeout to say 2 hours would direct the master process to kill the splits that are running for 2 hours and restart them? Any other recommendations?
This is the job setup I am using:
ocnxlJobSetup( '(
        "ADEXL_NB_POOL" "pool_name"
        "ADEXL_NB_QSLOT" "qslot_name"
        "blockemail" "1"
        "configuretimeout" "-1"
        "distributionmethod" "NB interface (free)"
        "lingertimeout" "30"
        "maxjobs" "240"
        "name" "Netbatch"
        "preemptivestart" "1"
        "reconfigureimmediately" "1"
        "runtimeout" "-1"
        "showerrorwhenretrying" "0"
        "showoutputlogerror" "1"
        "startmaxjobsimmed" "1"
        "starttimeout" "432000"
  • Tom Volden
    Tom Volden over 12 years ago
    Hi Tajinder,
     Based on the description, it sounds like the simulator is dying for some unknown reason and not returning an exit code to the ICRP process (the virtuoso process on the remote machine that you are manually killing in order to restart the point).  Unfortunately since the ICRP process is not receiving a return value back from the simulator it thinks everything is fine and just continues to wait for the simulator to report back that it has completed simulating the point.  Of course it waits forever since the simulator has apparently crashed.
    You have identified the workaround that I would suggest - setting the simulation timeout to a value 1.5-2X the expected time for a simulation to complete.  This gives some leeway for slower or highly utilized machines, but should recognize situations like you describe and try to kill the (non-existent) simulation and restart it.
    TOM
  • Tajinder
    Thanks Tom for taking the time to reply. I am not sure if runtimeout would work, but let me give it a shot.
  • Tajinder
    In the following scenario, the runtimeout didn't help.  I specifed rutimeout of 6 hours.
    The machine running split #1536 crashed (runICRIP325). Netbatch promptly restarted the job on a different machine.
    However this job failed right away as the die netbatch job didn’t remove the Job325.log.cdslck file.
     >>>Failed to lock log file: <blah><blah>/Job325.log
    The parent job is STILL waiting for last 24 hours.
    Suggestions?
