  3. I need help in replacing transistors
  • Views 15339
Ammar Abdou
Ammar Abdou over 12 years ago
Hi all,
I'm using virtuoso 6.1.4
I have a library that contains alot of schematics with alot of transistors.
My problem is :I want a fast way or methode to REPLACE all of these transistors from (let's say 130nm technology) to ( 65nm technology tsmc or something like that) keeping the W/L ratio,i can do that manually (one by one) but that will take very very long time,i believe that there must be an easier way to do that ,i mean if there is a command can be written in Comman Line Interface CLI that will be great !
Thanks in advance
Ammar Abdou
  • Quek
    Quek over 12 years ago
    Hi Ammar Abdou
    I think you can use the skillscript in COS article 11256326 to do the migration.
    Best regards
    Quek
