  3. nport Issue
  • Subscribers 133
  • Views 17913
nport Issue
archive over 18 years ago
I am simulating n4port element in spectre. My s-parameter file is in spectre format. I am using linear Interpolation. For my setup, I have a AC source connected to port 1+ as my input. I am doing AC frequency analysis and observing output at other 3 ports. I do not get any output on ports 2, 3 and 4. I see the entire signal on port 1-. Can you tell what my problem could be?
Let me know if you need anymore information.
Chintan Shah
chshah@ncsu.edu
Originally posted in cdnusers.org by shahch31
    archive over 18 years ago +1
    I figured out what my problem was. I needed to ground the negative terminal and on the positive terminal connect a pdc source on all 4 ports which would allow me to run a s-parameter simulation. I was…
    This is almost certainly because you've not terminated the nport with sensible impedances. The s-parameters were probably measured assuming 50-ohm (or something similar) ports - you can see this by looking in the s-parameter file.
    If you connect an ac vsource directly to an nport pin, it's going to do all sorts of horrid and unrealistic things.
    I just tried doing it, and I got similar results to what you describe, so I'm assuming you've just connected the circuit up inappropriately.
    Originally posted in cdnusers.org by adbeckett
    I figured out what my problem was. I needed to ground the negative terminal and on the positive terminal connect a pdc source on all 4 ports which would allow me to run a s-parameter simulation. I was not successful with running transient but I am assuming you won't be able to run transient for a nport element. Thank you for looking into this problem.
    Chintan
    I also got the transient simulation working. I forgot to include the model file. I connected a 50 Ohm resistor at the input and all the outputs. Thanks again for your help.
    Chintan
