  3. SpiceIn - how to map to a total width from w and m in the...
  • Views 5792
SpiceIn - how to map to a total width from w and m in the CDL
WMACH
WMACH over 12 years ago
I have used SpiceIn to import my CDL (which includes MOSFETS, diodes and resistors). I had good results except when it comes to MOSFETs. The issue is related to the fact that my MOSFET devices, in my cadence librasy, have width per finger "wf" and a calculated total width "wt", which would be taken care of by a callback whenever there is a change in "wf" or the multiplier "m".
In my device map I have a mapping from the width "w" in the CDL to the schematic in Cadence as "wf". Since "wt" is not being mapped, the callback assigns to it a default value, which is not necessarily the product of "w" x "m" from the CDL.
So, at this point in order to get the correct value of "wt" I have to query my MOSFET devices and "pretend" I'm making a change just to trigger the callback to do its job. The problem is that my schematic has hundreds of MOSFET instances and I have lots of schematics, so I manual way to do this would be really impractical.
Two questions:
1. Is there a way in SpiceIn to map to "wf" (schematic view) from "w" x "m" (CDL)? if so, how can I do that.
2. Is there a Cadence routine to make the change automatically as described above such that I can cause the callback to recalculate values? with this I could implement a routine to repeat this operation on every device in my schematic.
Any help would be greatly appreciated,
Thanks.
  • skillUser
    skillUser over 12 years ago
    Take a look at Solution Article 11724692 it should help you regarding mapping in Spice In and gives a reference to another solution regarding calling the callbacks.
    Also I'm attaching a SKILL code approach for copying one parameter to another in a schematic as a post-processing step to Spice In.  Although this does not quite do what you are asking, it should not be too difficult to modify it to set "wf" to the value of "m" * "w".  I would recommend the use of cdfParseFloatString() for reading instance parameters and converting them into a numerical value that you can perform mathematical operations on.
    Hopefully this information will help you?
    regards,
    Lawrence.
    CCScopyInstM.il
  • WMACH
    Hi Lawrence,
    Thanks for the link to Solution Article 11724692, which already provides a SKILL script to do what I need. I tried it and it works.
    Thanks for your script too, I will give it a try later.
    Thanks.
  • WMACH
    Correction!
    I've mixed solutions up. Actually in another post I found the solution below, which provides the SKILL script mentioned above.
    https://support.cadence.com/apex/homePage
    I'm sorry for the mix-up
    Thanks.
  • skillUser
    Great news! Actually Solution 11018344 is referenced in Solution 11724692 (as I'd mentioned: "and gives a reference to another solution regarding calling the callbacks"), I just didn't provide the link to it directly here.  This is probably your best option as it will run all of the device callbacks - the code I'd suggested would only change the one "wf" parameter on each device (and you'd have to write it!).
    I'm glad that things seem to be resolved.
    Best regards,
    Lawrence.
