  3. assura LVS unbound devices are IO cells
  • Views 16325
zczc99
zczc99 over 12 years ago
I am using assura for LVS, but failed with errors that unbound devices on schematic are IO cells.  I met the similar issues that unbound devices are like nmos, pmos, then I solved with "netlisting options --> use model property as device name if model in instparameters".
But here IO cells are unbound cells, I don't know what is the problem with this.
Anybody can help???
Thank you!
  • Quek
    Quek over 12 years ago
    Hi zczc99
    You can use avCompareRules abortOnUnboundDevices=nil to complete the run and then try to figure out the problem. It looks like the generic IO devices should be bound to the corresponding layout devices using "bind" cmd.
    Best regards
    Quek
