  3. Creating a user defined Voltage source
  • Views 16577
Debajit B
Debajit B over 12 years ago
I've been working on a analog front-end module for heart rate detector and want to test the design for ECG signals. I need to know how do I create my own voltage source after collecting ECG data from database and use it in verification.
Thank You,
Debajit
  • berndfi
    berndfi over 12 years ago
    You probably should have given an example of the ECG data.
    In the ‘analogLib’ there is a 'vpwlf' source which is a piecewise linear voltage source which accepts a
    file an input, this might be what you are looking for.
  • Debajit B
     ECG data samples are collected from Physiobank's signal archive and used as VPWLF's input file.
    Thanks a lot for the suggestion.
  • Debajit B
