  3. ADE XL - Message 1612
  • Views 2751
shayM
shayM over 12 years ago
When I try to run the simulation get the error:  "ADEXL -1612 : simulator not in path for the following tests: "
 how to set the path ? screenshot
    Assuming that it's spectre that you're trying to use, it's telling you that it can't find the executable for spectre in your UNIX path.
    So before you start "virtuoso", you'll probably find that "which spectre" can't find the simulator. You'd fix this by doing:
      set path = (/path/to/your/MMSIMinstallation/tools/bin $path)
    if using csh, or if using bash or ksh:
      export PATH=/path/to/your/MMSIMinstallation/tools/bin:$PATH
    (of course, change the /path/to/your/... bit appropriately).
    Check it's OK by typing "spectre -W" (to show the subversion of spectre). Then start virtuoso.
    If it's a different simulator, you need to make sure that the UNIX path is set up to access that simulator executable.
  • shayM
    Hello  Andrew.
    Thank you for your response.
    I use the Ubuntu operating system.
    should I put the following line in the terminal:
    " export PATH = /path/to/home/linux/cadence/virtuoso/bin/:&PATH " ?
    i am no familiar with linux OS
    TNX.
