  3. Spectre S-Parameter simulation
  • Subscribers 133
  • Views 21076
archive over 18 years ago
Can you simulate S-Parameter of RLC circuit in spectre? The schematic of my circuit is attached. I have 4 ports and would like to plot S-parameter?
Chintan Shah
Originally posted in cdnusers.org by shahch31
    Place "port" components from analogLib connected to each of the pins of your circuit - you can specify the port number on the port component, and specify the port impedance you want. Then use the "sp" analysis in spectre to compute the s-parameters.
    Originally posted in cdnusers.org by adbeckett
