  3. Wrong multiplier (m) factor being saved by Spectre
  • Views 17493
Wilmar
Wilmar over 12 years ago
I'd like to save and get back the "m" parameter of my circuit devices in order to make some design counts I'm interested in.
But, somehow the saved "m" value is always "1" in spite of the real value I assigned to it and Spectre actually used to run the simulation. I modify the multiplier "m" parameter either using the properties/CDF box in Virtuoso Schematic or manually editing the netlist.
To illustrate this, I just built a simple circuit with one transistor and run DC-sweep analysis with different values for "m". Its simplified netlist looks like this (I used montecarlo models in this one but it also happens with typical tt model):
simulator lang=spectre
parameters mdut=2 vgn_par=0.8
include "/.../silterra/silterraC18G_cadenceIC6/CL016/models/spectre/c16_header.scs" section=c16_hp_monte
MNUT (vgn vgn 0 0) mnhp w=7u l=7u as=3.36p ad=3.36p ps=14.96u pd=14.96u \
        nrs=68.5714m nrd=68.5714m m=mdut sa=480n sb=480n sd=0 nf=1
VG (vgn 0) vsource dc=vgn_par type=dc
oppoint dc print=yes oppoint=rawfile
dc dc start=10m stop=2 param=vgn_par step=0.01 maxiters=150 maxsteps=10000 \
    oppoint=no hysteresis=no
You can see the resultant waveforms in attached image, so it's clear that Spectre actually varies MNUT size using "m" and so its drain current does, but the saved "m" parameter is always "1". I wonder wheter this is related to either some Spectre simulation config or some PDK implementation issue.
I had a look to my PDK models and found out they state "m" like this:
section c16_hp_device
subckt nhp ( d g s b )
mint (d g s b) nhp  w=wf l=l sa=sa_comp sb=sb_comp ad=ad/nf pd=pd/nf as=as/nf ps=ps/nf nrs=nrs*nf nrd=nrd*nf m=(1*nf) delvto=delvto
ends nhp
subckt mnhp ( d g s b)
xmint (d g s b) nhp  w=wf l=l sa=sa_comp sb=sb_comp ad=ad/nf pd=pd/nf as=as/nf ps=ps/nf nrs=nrs*nf nrd=nrd*nf m=(1*nf)+(multn_hp * (aidn_hp/sqrt(w * l))) delvto=dvtn_hp * (avtn_hp/sqrt(w * l))
ends mnhp
Do you think that the statement "m=(1*nf)" has something to do with this?
Or maybe it is something related to Cadence save configurations?
Thank you in advance
    It's not "wrong" - but spectre does not output in an info analysis the overall effective m, including all the m factors given at higher levels of hierarchy. It only shows the m on the instance itself. Since nf=1, the m on the instance itself is shown as 1.
    A number of years ago, I filed an enhancement request, CCR 517729 "Would like info analysis to output overall m factor with what=inst". There was some discussion of what=allparameters outputing subckt m parameters, but the request was to give the effective overall m. Unfortunately there are no plans to implement this functionality currently (it's only come up a couple of times over the years). If you would like this, I suggest that you contact customer support and request that a duplicate is filed (and the master CCR reopened).
    Kind Regards,
    It turns out that it has been implemented as an "Output" parameter (rather than an operating point parameter), for BHT, BSIM3,bsim4, bsim6, mosvar, bsimsoi, jfet devices as part of CCR 1182684, in:
      mmsim131_isr5
      mmsim131_usr1
      mmsim121_isr18
    Output parameters can't (unfortunately) be annotated by default, but you can retrieve the value using (say):
    pv("/I7/M2" "meff" ?result "output")
    "meff" is the effective m-factor.
  • Wilmar
    Thank you Andrew.
    I was informed about this by the support team as I contected them referring the issue.
    And that is what I needed.
    Best regards,
