  3. Switched Capacitor Bandgap Reference LVS Issue
  • Views 15843
Jake98
Jake98 over 12 years ago
I am minutes away from completing my design of a switched capacitor bandgap voltage reference.  However, when I do LVS verification, the comparison results window shows up empty, but the report states INCORRECT.  I cannot see what I need to fix.  If I open the report specifically from my LVS directory, it states everything is correct (including cell comparison) except for a single error: "Components with non-identical signal pins."  But it does not tell me what should be corrected anywhere.
I have never seen this happen before.  I can run LVS on other circuits and it behaves normally.  Even lower level subcircuits within this design are LVS clean.  But the top level shows up blank in comparison results LVS tab, but report states in overall comparison results "Components with non-identical signal pins" as an error.
I checked all of my signal labels and they are on the correct nodes and layers.
Has anyone seen this before or have any suggestions?
Jacob Shelton
  • Jake98
    Bump
    Jake98 said:
    Bump
    Posting "Bump" won't get this answered any quicker. It generally just irritates people, in fact. This is a community forum, and urgent issues should be addressed to customer support which has a proper mechanism for tracking cases and escalating urgent issues. The community forums are manned by volunteers using their free time (some from Cadence, and many from the industry).
    I did do a quick search and couldn't find anything relevant - it didn't ring any bells. So it would be best if we can see the data, which is something that also can be done if using customer support.
    Kind Regards,
  • Jake98
    I actually figured out my own issue, something to do with schematic netlist generation for comparison. But thanks for the "quick reply"
