  3. spectre terminated prematurely due to fatal error.
  • Replies 7
  • Views 29790
hTmTech
hTmTech over 12 years ago
hello ,
I still have this simulation error message  " spectre terminated prematurely due to fatal error."  with cadence virtuoso
What is the problem ??
thanx
    The problem is that it terminated with a fatal error! Some error happened which was fatal...
    It would help to see the entire spectre.out log file to understand if it gives more information as to the reason.
  • hTmTech
    here the full error message :
    Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
    Version 12.1.0.347.isr3 32bit -- 10 Jan 2013
    Copyright (C) 1989-2012 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
    Protected by U.S. Patents:
    Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
    Simulating `input.scs' on ubuntu at 5:09:52 PM, Sun May 11, 2014 (process id: 2154).
    Current working directory: /home/htn/simulation/schema/spectre/schematic/netlist.
    Command line:
        /home/htn/htntools/mmsim/tools.lnx86/spectre/bin/32bit/spectre  \
            input.scs +escchars +log ../psf/spectre.out +inter=mpsc  \
            +mpssession=spectre0_1857_1 -format psfxl -raw ../psf  \
            +lqtimeout 900 -maxw 5 -maxn 5
    spectre pid = 2154
    Loading /home/htn/htntools/mmsim/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
    Loading /home/htn/htntools/mmsim/tools.lnx86/cmi/lib/5.0/libphilips_o_sh.so ...
    Loading /home/htn/htntools/mmsim/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
    Loading /home/htn/htntools/mmsim/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
    Loading /home/htn/htntools/mmsim/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
    Reading file:  /home/htn/htntools/simulation/schema/spectre/schematic/netlist/input.scs
    Time for NDB Parsing: CPU = 1.99612 s, elapsed = 8.79741 s.
    Time accumulated: CPU = 1.99612 s, elapsed = 8.79741 s.
    Peak resident memory used = 38.2 Mbytes.
    Error found by spectre during circuit read-in.
        ERROR (SFE-23): "input.scs" 12: PM0 is an instance of an undefined model pmos1.
        ERROR (SFE-23): "input.scs" 17: X0 is an instance of an undefined model f_opAmp.
    Reading link:  /home/ht/htntools//mmsim/tools.lnx86/spectre/etc/ahdl/discipline.h
    Reading file: /home/htn/htntools/mmsim/tools.lnx86/spectre/etc/ahdl/disciplines.vams
    Reading link:  /home/htn/htntools/mmsim/tools.lnx86/spectre/etc/ahdl/constants.h
    Reading file: /home/htn/htntools/mmsim/tools.lnx86/spectre/etc/ahdl/constants.vams
    Time for Elaboration: CPU = 36.002 ms, elapsed = 266.443 ms.
    Time accumulated: CPU = 2.03613 s, elapsed = 9.07521 s.
    Peak resident memory used = 40.7 Mbytes.
    That explains it pretty clearly. This is why it's worth checking the whole file, not just the last line. You haven't specified your models. From the second one, I'm guessing you're using the (rather ancient) functional library. As described in the documentation for this library, you need to include:
    <ICinstDir>/tools/dfII/etc/cdslib/artist/functional/allFunc.scs
    in your model libraries (Setup->Model Libraries in ADE). Then it will find the definition of f_opAmp. Note however that this library contains very old macro-models which pre-date VerilogA (which is a far more powerful way of modelling behaviour).
    As for pmos1 - this is presumably related to the transistor you are using. I don't know whether this is from design kit or other, or a sample from Cadence - but you also need to locate and reference (via Setup->Model Libraries) the models that this uses. There is a model called "pmos1" in gpdk180 (the 0.18um Cadence Generic Process Design Kit), which you'd get if you included <GPDKinstDir>/models/spectre/gpdk.scs section NN in the model libraries. But I don't know if that is what you're doing. And if you're using gpdk devices, this should be added automatically when you start ADE.
  • sona kaur
    sona kaur over 7 years ago in reply to Andrew Beckett
    hi sir i also have that same prematurely fatal error.. how to remove it??????
    Andrew Beckett over 7 years ago in reply to sona kaur
    Well, if it's the same "premature fatal error" as above, I explained above how to fix it. If it's not the same fatal error, you'll need to provide some details...
  • mohsinjutt
    mohsinjutt over 6 years ago in reply to Andrew Beckett
    hello sir i have the same error can you help me please
    Andrew Beckett over 6 years ago in reply to mohsinjutt
    Please read the rest of the thread in this post. If you have the same problem, then I explained how to fix it. If it's not the same error, then you'll have to provide the entire log file so that I can understand what the issue is and advise how to fix it.
    Oh, and the forum guidelines ask you not to post on the end (or in this case the middle) of existing threads.
