  3. use of run(?sgeHardResources "Virtuoso_Multi_mode_Simulation...
  • Views 785
use of run(?sgeHardResources "Virtuoso_Multi_mode_Simulation=x") option
Battosai13
Battosai13 over 12 years ago
 Hi all
I am trying to use SGE for distributed simulation. When I run a simulation from ADE it all works well as expected. When I use an ocean script with the following additions for use with SGE:
hostMode('distributed')
run(?jobName "myJob" ?queue "myQueue" ?block 't ?sgehardresource "Virtuoso_Multi_mode_Simulation=2"
openResults('myJob)
The problemI ran into is that the simulations never start even though SGE starts the job and ends it successfully. I noticed that removing the sgehardresource option solves the problem and the simulation works perfectly. Unfortunatly I need this option in our setup!
The logfiles show no difference exept that the log messages of the analyses are missing (thats how I now the simulation never ran). In addition I found out that using the option produces a difference in the input.scs file. The following lines are missing:
dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
dcOpInfo info what=oppoint where=rawfile
stb stb start=1e0 stop=1e9 dec=100 probe=IPRB0 annotate=status
These are exactly the analyses I am trying to run. Am I using the sgehardresource option in the run() command wrong or is this a genuine bug?
Does anyone have experiance with this option?
Cheers, Samuel
  • Battosai13
     Hi All
    I have resolved the issue: The command sgeHardResource in the oceanReference is spelled wrong. It should be sgeHardResourceSrt
    run(?jobName "myJob" ?queue "myQueue" ?block 't ?sgeHardResourceStr "Virtuoso_Multi_mode_Simulation=2"
    Cheers, Samuel
