  3. Best way to make a serial stream (SPI) for VPWLF?
  • Views 15644
bpdegnan
bpdegnan over 12 years ago
I am trying to come up with a good way to generate a serial stream.  It seems that VPWLF sources would be the best way to do it.  I'm basically trying to simulate a SPI bus (but it's actually AER), but I don't feel like having 100s of entries by hand.  If anyone has any advice, it would be greatly appreciated.
 --bpd
  • bpdegnan
    As I received no other ideas, I just wrote my own stream creator.  I made the jar available for anyone else who needs something similar in the future.
    https://sites.google.com/site/degnan68k/semiconductors/spicespi
    Spectre does have the ability to have a vector file input (on Setup->SImulation Files form in ADE) where you can specify how a set of digital signals vary over time (in different number bases) along with data to tell it the voltage levels, rise/fall times etc. There is a chapter in the UltraSim documentation which covers the formats in more depth (it also supports VCD - Verilog Change Dump format).
    Sorry if that makes your Java code redundant (it's always nice to have a fancy UI though ;-> )
