  3. Global Nets
  • Views 16127
Global Nets
MAAASD
MAAASD over 12 years ago
 Hi guys, I hope all is fine. I have seemingly a simple question, for the schematic below i want to connect the voltage source nets to all
the input pins of the compenet; i know that one solution is to add wires to these pins and name them same names as the power nets
but for a large design this is a very tedious task. So what i want to do is just adding the power sources and give them names as the input pins of the instant, hopfully, all instants pins with the same name will be connected to the power sources matching their name. Is that applicable? I tried the schematic below but the o/p was wrong, meaning that it doesn't understand my connections. Any help?
Thanks in advance.
Schematic
  • Quek
    Quek over 12 years ago
    Hi MAAASD
    It is not necessary to add wire stubs to each instance manually. You can simply select all the target instances in navigator and execute "Create->Wire stubs and names". This will create VSS, VBN, etc wire stubs for your gates.
    Best regards
    Quek
  • MAAASD
     Thank you very much, sir :)
