  3. ADEGXL global optimisation runs only 9 jobs in parallel
  • Views 15114
vamshiky
vamshiky over 12 years ago
 I am trying to use global optimsation for finding w/l of a mosfet while forcing the vgs-vth to be in some range like 100mv to 105mv.
In this setup I notice that only 9 sims are launched at a time, though the job policy which I use can take upto 100.(with adexl) and hence tales a lot of time to complete the optimisation.
Is there any other setting which will speed up this.
Vamshi
  • Tom Volden
    Tom Volden over 12 years ago
    Hi Vamshi,
    ADE GXL's global optimization uses a parallel simulated annealing algorithm to explore the design space.  This type of algorithm can efficiently explore large multi-variable design spaces.  It sounds to me from your description that you have only a couple of variables, therefore the number of simulations needed to calculate the next area of the design space for exploration is much smaller than your maxjobs setting.
    TOM
  • vamshiky
    Hi Tom,
    Not really.  To elaborate this is what I have tried .
    I have 24 mosfets with Length defined  in the schematic with each of them having 'finger width' and 'number of fingers' as parameters. so total of 48 variables.
    In the global variables section each of them are given with a range like 2:2:20 etc.
    And when I launch global optimisation(with spec of vgs-vth in a range) I see that there is a huge design space ( about 4e+30 of runs)
    However I still notice only 9runs in parallel.
    I am looking  for an efficient way of optimising the sizes here, so that I can tabulate widths for different 'vgs-vth' of a device for a given length.
    Vamshi
