  3. auCdl view and loading CDF port order through CIW?
  • Views 17634
yayla
yayla over 12 years ago
I have a netlist provided by a different team and my port order in Cadence doesn't match the provided netlist. What we are doing is that we are generating auCdl view from symbol. Then, we have a script to generate a cdf file(attached below)  and load into CIW in Cadence. From CIW=>Tools=>CDF, I can see the new correct port order but when I need to netlist, Cadence doesn't still use the new order.
I found this document but it didn't help me much. This suggests sth about “auCDFPinCtrl”  but don't know how to incorporate.
http://lost-contact.mit.edu/afs/rose-hulman.edu/cadence-0910/IC610/doc/anasimhelp/appC.html#938197
yayla
 LIBRARY = "test_lib"
 CELL    = "test_cell"
let( ( libId cellId cdfId )
    unless( cellId = ddGetObj( LIBRARY CELL )
        error( "Could not get cell %s." CELL )
    when( cdfId = cdfGetBaseCellCDF( cellId )
        cdfDeleteCDF( cdfId )
    cdfId  = cdfCreateBaseCellCDF( cellId )
    ;;; Parameters
    cdfCreateParam( cdfId
        ?name           "macro"
        ?prompt         "Subcircuit Filename"
        ?defValue       "gv_pr"
        ?type           "string"
        ?display        "!cdfgData->template->value"
        ?editable       "nil"
        ?parseAsCEL     "yes"
    ;;; Simulator Information
    cdfId->simInfo = list( nil )
    cdfId->simInfo->ams = '( nil )
    cdfId->simInfo->auCdl = '( nil
        namePrefix        "X"
        termOrder         ("a" "b" )
        componentName     "subcircuit"
        netlistProcedure  ansCdlSubcktCall
    cdfId->simInfo->hspiceS = '( nil
        namePrefix        "X"
        macroArguments    nil
        netlistProcedure  ansSpiceSubcktCall
    cdfId->simInfo->spectre = '( nil
        opParamExprList   nil
        stringParameters  nil
        propMapping       nil
        termMapping       nil
        instParameters    nil
        otherParameters   nil
        termOrder         ("a" "b")
        componentName     gv_pr
        netlistProcedure  nil
    cdfId->simInfo->spectreS = '( nil
        namePrefix        "X"
        macroArguments    nil
    ;;; Properties
    cdfId->formInitProc            = ""
    cdfId->doneProc                = ""
    cdfId->buttonFieldWidth        = 340
    cdfId->fieldHeight             = 35
    cdfId->fieldWidth              = 350
    cdfId->promptWidth             = 175
    cdfId->paramLabelSet           = "-macro"
    cdfId->paramDisplayMode        = "parameter"
    cdfId->paramEvaluate           = "t nil nil nil nil"
    cdfId->instDisplayMode         = "cellName"
    cdfId->instNameType            = "schematic"
    cdfSaveCDF( cdfId )
  • yayla
    I figured out how to solve the problem which is already at the link I have provided before but I didn't notice at that time. What you need to do is create a .simrc file and put auCdlCDFPinCntrl='t this line inside that file.
     thanks,
    yayla
