  3. Assura LVS for Standard Cell Library with only Abstract...
  • Views 16904
Assura LVS for Standard Cell Library with only Abstract View
alperro
alperro over 12 years ago
Hi everyone,
I am trying to perform an LVS run with a block which is streamed in from Encounter and a simple custom inverter layout which is drawn by me. My standard cell library contains cells with abstract views, therefore I need to use black box technique. I am using a simple CDL netlist for this purpose and I set related to compare rules on Assura GUI.
 I managed to match the netlist and layout to certain point. The problem is, in the layout of the block which is imported from Encounter, appears two ground pins which are named as avS** and avC** and prevents the match. I call them ground pins since in the layout VNL netlist they defined so.
 Any idea why this is happening and  how to deal with them?
(Note: Any decent document related to this kind of flow will be highly appreciated)
Best Regards!
Alper
  • Quek
    Quek over 12 years ago
    Hi Alper
    This can sometimes happen for Assura blackboxes. It is due to the way the extract rules are coded. You should be able to resolve it by adding substrate and well taps in the blackbox cells.
    Best regards
    Quek
  • alperro
    Hi Quek,
    The problem was indeed in the substrate connections. First I had tried to add substrate connections to top level layout however it didn't work. It seems that I should have put substrate taps to layout of the placed and routed block additionaly.
     Thanks a lot!
     Best regards.
    Alper
  • Daihyun
    Daihyun over 8 years ago in reply to Quek
    Hi Quek, cna you describe this a bit further? I have an issue in bicmos8xp. I want to run LVS on custom inductor layout as blackbox but M1 ground layer keeps causing similar issue by generating additional avCx and avSx pins. If I use other layers than M1, it works fine. I tried to add subc contact but it doesn't help. Do you have any idea how to avoid this issue?
  • Quek
    Quek over 8 years ago in reply to Daihyun
    hi Daihyun
    Would you please try adding ?blackBoxCell avParameter cmd to see if it helps?
    By the way, this thread has already ended more than 4 years ago. It would be best if you can start a new thread for your issue. This will help us to focus on only your issue and not be confused by old comments.
    Best regards
    Quek
