  3. Unable to get license feature
  • Views 15478
moo911940
moo911940 over 12 years ago
I downloaded Xwin and setup Cadence using these instructions from my university:
www-scf.usc.edu/.../tools_setup.htm
When I attempt to open Virtuoso from Xwin, I get the error:
cdsGetFastTime:shmget failure: No such file or directory.
*ERROR* (DB-320001): Unable to get Cadence(R) Design Framework II license feature of "111".
 What does this error mean and how do I fix it?
  • skillUser
    skillUser over 12 years ago
    Which version of Virtuoso are you trying to use, and on which platform? I don't know what Xwin is but it sounds like an X window emulation package - if so, it is not supported by Cadence for running Virtuoso.  You might try different packages such as NoMachine, VNC and Exceed (these are not officially supported either, but are much more commonly used, so most 'kinks' have been ironed out).
    regards,
    Lawrence.
