  3. Layout XL- Matched Length Constraint
  • Views 2787
KarthikJaiho
KarthikJaiho over 12 years ago
 Hi friedns,
         Can anyone Please help me on this. How to use Matched Length Constraint in Schematic XL as well as in layout XL. I am using virtuoso IC6.1.5.
 Thanks & Regards
 Karthik
  • Marc Heise
    Marc Heise over 12 years ago
     Hi Karthik,
    Matched Length is a net constraint, means you need to select two nets  ( in the Navigator Assistant) and select that constraint in the Constraint Manager. There is a large section about it in the Constraint User Guide so I would advise to read the documentation.
     There you also find this:
      Supporting Applications:
    Virtuoso Space-based Router, Virtuoso Layout Optimize, Virtuoso Layout Migrate / Yield Optimize, Encounter Digital Implementation (EDI)
    So you see that the interactiv wire editor in the layout tool is not watching that constraint.  Please read the documentation, and if there is still a question open, come back and ask.
    Kind regards,
    Marc
  • Quek
    Quek over 12 years ago
    Hi Karthik
    The matched length constraint is meant to be used by Virtuoso Space-based Router (VSR) and not for controlling of net length during manual routing. When matched length constraint is set on 2 nets, an autorouter will attempt to match it using different techniques. One commonly applied technique is to create "S" shapes on one of the nets to lengthen it so that it matches the length of the other net.
    Best regards
    Quek
  • KarthikJaiho
     Hi Quek
                       Thanks a lot for your reply.
    Karthik
