  3. Using spice in cadence
  • Subscribers 133
  • Views 16264
archive over 18 years ago
Hello All,
I'm trying to use a spice netlist directly in the ADE.
It works well using simple spice models like transistors, diodes...
But could someone help me on how I have to implement a schematic in order to use a spice subcircuit?
I have the following subcircuit writen in a scs file:
simulator lang=spice
.SUBCKT My_MOSFET 1 2 3
.ENDS
where nodes 1 = drain, 2 = gate, 3 = source.
How can I link the nodes 1, 2 and 3 to the terminals a cadence schematic/symbol?
Or do you have another mean to use a spice netlist? (the spice-spectre conversion spectrespp fails).
Thanks for your help.
Best regards,
Axel
Originally posted in cdnusers.org by axp
    Hi Axel,
    Just create a symbol for it and then reference the subckt with a "model" CDF param.
    Please see the following Sourcelink Solution:
    http://sourcelink.cadence.com/docs/db/kdb/2007/May/11336612.html
    Eric
    Originally posted in cdnusers.org by EricCDN
