  3. Unable to run Monte Carlo ADEXL-1723
  • Views 15414
Faizalism
Faizalism over 12 years ago
 I have problem to run monte carlo analysis as there is pop-up window mentioned as below (bold):
ADEXL-1723: Unable to run Monte Carlo analysis because the version of the simulator associated with the following tests does not support Monte Carlo analysis:
Use the version of Ultrasim or AMS that supports Monte Carlo...
FYI, I am running AMS simulation using AMS (with spectre solver) simulator.
Btw, when I checked Cadence Help, AMS simulator with spectre solver is supported for Monte Carlo analysis, but there is Note mentioned as below:
 Ensure that you are using Cadence IUS 9.2 or later version of Virtuoso AMS Designer simulator.
 How I would know my cadence version? i.e whether it is Cadence IUS 9.2 or not?
    In the UNIX terminal that you started virtuoso from, type "ncsim -version".
  • Faizalism
    Thanks Andrew. >ncsim -version TOOL: ncsim 08.20-s004 Can I say that my Cadence version = 8.20, hence not supported for Monte Carlo analysis using AMS simulator?
    Yes, it's too old. There have been 7 major releases of the Incisive stream since then. The current is INCISIV132:
    TOOL:   ncsim   13.20-s009
