  3. pipo.log and strmOut.log
  • Views 17162
radiowaves
radiowaves over 12 years ago
I am using IC 6.16. Is pipo.log the same as strmOut.log in IC 6.16?
    pipo.log is the output from the stream interface in IC5141, and strmOut.log is for the stream interface in IC61X. The tools used are different so the files are not identical, but they are for similar tasks and so have similar contents (but not identical).
  • radiowaves
    Thank you very much!
