  3. Sweeping component parameters for many components in ADE...
  • Views 14492
Sweeping component parameters for many components in ADE GXL
Kabal
Kabal over 12 years ago
Let's say I have 20 transistors in a circuit and all of them have same value of W.
If I want to DC sweep that W as a component parameter, the tool only allows you to select one component. But I need to sweep W which is common to ALL transistors in a circuit.
How can I achieve that?
The most obvious solution was to declare a Variable and then use that variable as a W value for all transistors, then just sweep that variable.
However, for some reason, I get total nonsense with that approach! The DC paramer values are just total crap! They do not make sense. And I verify that by saving a dc points and plotting them separately. For example, If I choose to sweep W variable which is used as a value for w parameter for all transistors, first thing I notice is, the plots of DC and the annotated DC operating points are completely different. Second, when I enter that value numerically instead of W for every transistor, and remove sweep, it shows completely different behaviour. Not sure why it is like that, it started doing that since last install of IC6.16
So the bottom line is, for some reason ADE GXL doesn't like me to achieve what I described using a regular variables.
That's why I want to know any alternative method.
And of course, I do not understand how come the voltage of some circuit nodes when plotted have one value, but annotated on schematics with another value? The initial sources have values which should force the voltages which I see in plots, but that is not the case.
