  3. How to change the template of MPP in Properties form?
  • Views 15708
DesmondLiu
DesmondLiu over 12 years ago
    What if customer has already created a MPP but they want to change the template defined in tech file?
I can't find any UI options or SKILL function could do this. Thank you in advence.
    You can't. Two reasons:
    1. There is no record on the MPP as to which template was used.
    2. There's no means to re-apply a new template to an existing point list.
    Potentially you could use my SKILL code in solution 11323850 to create a new MPP using the same master path as the existing MPP, and then delete the original.
  • DesmondLiu
    Thanks Andrew, this code works well.
