  3. Labels are created in VLE while doing streaming in a GDS...
  • Views 14956
Labels are created in VLE while doing streaming in a GDS file.
RFStuff
RFStuff over 12 years ago
 Dear All,
I streamed in  a GDS file into a new library. While opening the top-level cell of the  library in the layout editor (VLE) , I find a lot of text labels ( like I1,I2...I1667) are created in the editor.
What I should do so that these labels will not be created automatically.
I am using  IC5141-sub-version 5.10.41.500.6.151.
Kind Regards,
    Presumably it's because the stream file has lots of labels in it. I don't believe there is a way of preventing the creation of labels in IC5141 or IC616, other than post-processing the results of the stream in to delete them (I tried scaling the label size in IC616, but I ended up with 0 height labels, which was not good!)
