  3. Abstract Generator : Memory instance ABSTRACT&LEF views...
  • Views 3303
Abstract Generator : Memory instance ABSTRACT&LEF views Generation.
samung
samung over 12 years ago
I have sucessfully generated the ABSTRACT & LEF views for a standard-cell with the Abstract generator Tool, now I am trying to do the same for a memory instance which contains many cells (master control, array of bitcells, io ...).
I have as input file : the layout of the memory instance, with all the input/ouput pins at the edges of the memory instances. Actually, the other intergrated blocks will communicate through these edged pins.
As far as now, the memory instance, contains all the cells (no flattened).
When I do the "Abstract Generation : Pin step" with Abstract Generator, I have the following messages, the step ends.
Log extract :
WARNING   (ABS-1502): Couldn't open master "cmosXXX_XXX_memMacros, top_blXXX_lresref, layout", referenced in cellview "cmosXXX_XXX_memTemplates_XXX, Inst_cellName, abstract.pin"
WARNING   (ABS-1502): Couldn't open master "cmosXXX_XXX_memMacros, array_blXXX_wlXXX_lresref, layout", referenced in cellview "cmosXXX_XXX_memTemplates_XXX, Inst_cellName, abstract.pin"
LOG       (ABS-1422): Running Pins 100 percent complete...
LOG       (ABS-1301): Cell Inst_cellName: Step Pins finished
1
REPLAY    (ABS-1429): 15  absSetCellProp("Inst_cellName" "symmetry" "None")
WARNING   (ABS-325): Cell Inst_cellName: Failed to set the property because the cell is either invalid or does not contain any of the valid views.Abstract Generator can set properties only on valid views, such as Pins,Extract,Abstract, that it has created.
ABS-1502 :
Message:
Couldn't open master libName, cellName, viewName, referenced in cellview libName, cellName, viewName.
My abstract.record is :
absSkillMode()
absSkillMode()
absSetLibrary("cmosXXX_XXX_memTemplates_XXX")
absAttachTechLib("cmosXXX_tech")
absSelectCellFrom("Inst_cellName" "Inst_cellName")
absDisableUpdate()
absSetBinOption("Core" "PinsPowerNames" "vdd1 vdd2 vd3 vdd4 vdd5")
absSetBinOption("Core" "PinsGroundNames" "vss")
absSetBinOption("Core" "PinsOutputNames" "q")
absSetBinOption("Core" "PinsClockNames" "clk")
absSetBinOption("Core" "ExcludeExistingTerminals" "")
absSetBinOption("Core" "PinsBoundaryCreate" "off")
absEnableUpdate()
absPins()
absDisableUpdate()
absSetBinOption("Core" "ExtractSig" "false")
absSetBinOption("Core" "ExtractMustJoinAlways" "true")
absSetBinOption("Core" "ExtractPwr" "false")
absSetBinOption("Core" "ExtractMustJoinAlwaysPwr" "true")
absSetBinOption("Core" "ExtractAntennaGate" "(PO (PO and (DCO or PP or NP or VTH_P or VTH_N or VTL_P or VTL_N or OD ))) ")
absSetBinOption("Core" "ExtractUseNetInfo" "true")
absEnableUpdate()
absExtract()
absDisableUpdate()
absEnableUpdate()
absAbstract()
absSetOption("ExportLEFFile" "cmosXXX_XXX_memTemplates_XXX.lef")
absExportLEF()
absExit()
Command line :
xxx/bin/abstract -replay xxx/cmosXXX_XXX_memTemplates/abstract.record -log abstract_batch.log -nogui
Can someone has some guidelines for the memory instance Abstract&Lef views Generation ?
Thanks a lot !
P.
PS : tool version : cadence_amsams2010.2c_mmsim &  IC6.1.5-64b.500.9
  • samung
    Actually, I managed on a testcase : layout of 2 standard-cell abutted, to generate the views (ABSTRACT, LEF, CEL, FRAM).
    However, I had to do a flatten of the 2 cells to solve the previous ABS-1502 warning. BUT, for the memory instance, I cannot do any flatten, so does someone has some guidelines ?
    Thanks !!
    P.
  • ColinSutlieff
    ColinSutlieff over 12 years ago
     Hi
    unfortunately I don't think this forum can help with this issue:
    You need to find out yourself why the views are not readable. Check for any lock files and file permissions.
    Colin
  • samung
    Hello Colin,
    thanks for the reply. Actually, I dont have any lock file neither wrong right permission.
    However, i had my working library for the "memory instance", containing just the layout. When I add the schematic, I don't have the warnings of the kind :
    but , I have the warnings one hierarchy level below, such as :
    WARNING   (ABS-1502): Couldn't open master "cmosXXX_XXX_XXX_sp, ctoplres1x1, layout", referenced in cellview "cmosXXX_XXX_memMacros, top_blXXX_lresref, layout"
    P.
