  3. Vbit Source
  • Views 18266
Vbit Source
DigitalOsama
DigitalOsama over 12 years ago
Dear All,
I'm using Vbit source to enter the following data pattern to a circuit as a stimulus
p1 pattern data="10101"
Why i didn't get a pulse wave and  got the attached wave?, and how can i generate a pulse wave using vbit source.
Osama
Vbit.tar.gz.tar.gz
    Which version of the simulator are you using? I just tried with MMSIM13.1 and it works fine for me.
  • DigitalOsama
    Hello Andrew ,
    I'm using MMSIM10.1
    Osama
    It appears to be broken in earlier MMSIM10.1 versions. I still see it broken in  10.1.1.017 but it's working OK in 10.1.1.441.isr25 (from 25th July 2012). Similarly it works in latest hotfix versions of MMSIM11.1, MMSIM12.1 and MMSIM13.1 - each of which are available on downloads.cadence.com
