  3. Complete procfile/p2lvsfile syntax
  • Views 2234
ggupta85
ggupta85 over 12 years ago
Hi Friends,
I need forum's help to point me to the complete procfile/p2lvsfile syntax. I have tried searching the web and the Cadence product documentation but couldn't find a very comprehensive guide for my purpose.
Any help in this matter will be hghly regarded.
Thanks in advance!!
    This is in the documentation in your QRC or Assura. It is however obsolete and ICT should really be used instead. It used to be the format for Assura RCX, but that has long been replaced by QRC.
    In the QRC documentation (the EXT13.2 release, for example), in the Assura RCX to QRC Migration Guide, chapter 2 "Creating a Process File", it explains how to do this. This will be in your EXTXX.Y installation, if you run cdnshelp  and search for "procfile". Or you can look at <EXTinstDir>/doc/qrcxRcxMigration/qrcxRcxMigration.pdf and look at chapter 2.
    It's also in the Assura documentation for Assura RCX. This is in the "Assura Physical Verification Developers Guide", in the chapter on "Assura RCX and Capgen Setup", in Step 2 (Create a Process Description File). This is in <ASSURAHOME>/doc/assuradev/assuradev.pdf
