  3. Decoder Cadence ADE Simulation problem
  • Views 22515
rajrevanth61
rajrevanth61 over 12 years ago
Hello Experts,
I was designing a 2x4 decoder for my use in the implementation of FPGA CLB. when i try to simulate the decoder circuit using the cadence ADE i am getting errors as below. I am also attaching my schematic and the circuit(created by importing the symbol and adding the voltage sources) i used for the simulation.
Please help me I am stuck.
WARNING (OSSHNL-117): Ignoring switch view 'schematic' of cell 'gnd' in library 'basic', as it does not contain
any instance. To netlist this cell, add this switch view to the stop list or to
ignore any specific instance set the property 'nlAction' to value "ignore" on
this cell view.
WARNING (OSSHNL-117): Ignoring switch view 'schematic' of cell 'vdd' in library 'basic', as it does not contain
this cell view.
WARNING (OSSHNL-160): The primitive, 'NCSU_Analog_Parts/vdc/spectre', was not used in the last netlisting session in this
current run directory. Therefore, re-netlisting all cell views where this
primitive is instantiated.
Netlist Warning: The netlisting procedure specified for (NCSU_Digital_Parts nfet spectre) is
obsolete. You can convert your library with the
Tools - Conversion Tool Box menu on the CIW.
*Error* ilGetString: arg must be symbol or string - progn(bn)
decoder schematic
    this cell view.
    These warnings will happen if your schematic has instantiated basic/gnd/schematic and basic/vdd/schematic rather than instanting the symbol view. It will still work, but you should really use the symbol view.
    It looks as if the NCSU libraries are old, and need updating. They probably were set up to use with the old spectreS interface which was replaced in about 1999. The progn(bn) approach hasn't been used since then and is not supported by the tools in recent versions, for a start, and it's also telling you that the netlisting function is obsolete.
    Maybe you should just use vdc and nmos4 etc from analogLib, or use a generic PDK (e.g. gpdk090 or gpdk045) instead?
    Or contact NCSU to find out if there's a newer version of these libraries.
