  3. VerilogA compiler
  • Replies 11
  • Views 23807
VerilogA compiler
Sali
Sali over 12 years ago
 Dear all,
I'm using VerilogA model in my design in Cadence, I have some variables in the model that should be changed with time, actually I have two questions:
1- Is there a way to display the value of those variables during the analog simulation? I was looking for VerilogA compiler to test my code first but I didn't find, can some one suggest me a website or any information?
2- The statement of  @(initial_step), does it mean the command after it will be exceuted only one time, which is the begining of the simulation?
Thank you in advance,
    Sali said:
    It works with me now, but the question is can I use ddt and ddx to model the differential equation? I'm asking this question because ddt gave me unexpected result, I use it to test when the curve reached the stable point (becames fixed to a certain value for the rest of the simulation) so I expected the ddt to be changing until becomes zero when the curve becomes stable but it always gives me 3 althogh the curve is stable after a certain period of time?
    Not enough info to go on, which was part of the reason for there being no answer. As Tawna said, anything urgent should go to customer support.
    and is there a way to build a model in Cadence using a high level language liek C++?
    It can be done, but it's really geared up for device modelling rather than high-level modelling. It's also available via a special license because it needs dedicated support, usually. So the answer is really no.
