  3. VerilogA compiler
  • Replies 11
  • Views 23804
VerilogA compiler
Sali
Sali over 12 years ago
 Dear all,
I'm using VerilogA model in my design in Cadence, I have some variables in the model that should be changed with time, actually I have two questions:
1- Is there a way to display the value of those variables during the analog simulation? I was looking for VerilogA compiler to test my code first but I didn't find, can some one suggest me a website or any information?
2- The statement of  @(initial_step), does it mean the command after it will be exceuted only one time, which is the begining of the simulation?
Thank you in advance,
    You can use the $strobe or $display (or even $debug) task to display information during simulation. You can also use the "saveahdlvars" option on the Outputs->Save All form in ADE and then you can plot any variables versus time (you'll need to use the results browser to access them) and then you can see how they vary.
    And yes, the Initial_step means that it will execute at the beginning.
    See the VerilogA documentation (Run <MMSIMinstDir>/bin/cdnshelp to bring up the documentation, and you'll be able to find the VerilogA reference manual within that).
  • Sali
     Thank you so much for your help.
    Actually I'm looking also for the potentiometer, I didn't find such a device under any library, any idea?
    It's not clear to me what the potentiometer model would do - would the control input be a non-electrical discipline describing the angle of turn of the pot, or the ratio through the potential divider? Or would it be a parameter?
    It doesn't sound terribly difficult to implement (since it's just a potential divider). If it was controlled by a parameter, something like this (completely untested):
    `include "disciplines.vams"
    module potentiometer(PLUS,MINUS,TAP);
    inout PLUS, MINUS, TAP;
    electrical PLUS, MINUS, TAP;
    parameter real ratio = 0.5 from [0:1.0];
    parameter real r = 1k;
    analog begin
      V(PLUS,TAP) <+ I(PLUS,TAP)*(1-ratio)*r;
      V(TAP,MINUS) <+ I(TAP,MINUS)*ratio*r;
    end
    endmodule
  • Sali
     Thank you so much for your help, I'm going to try this model and see.
    I have one more question please, when I execute the "ddt" operator inside if statenment it gives an error , I need the derivative to be zero as a condition to implement some code, any idea ?
     Thank you again,
    You should be able to put the ddt outside of the if, and then use the results of it inside the if, possibly to compute a result based on that. Bit difficult to be precise without knowing what you're trying to do. The reason it complains is that the derivative needs to be computed on every iteration of the solver, and if it is placed inside a conditional statement, it would not be executed all the time.
  • Sali
     Thank you for your reply
    Actually I ran the following and I'm still have the error of "Error found by spectre during AHDL read-in.
        ERROR (VACOMP-1554): "/home/thesis/Chua3/CalculateTheWeightR12/veriloga/veriloga.va", near line 25: Encountered an attempt to access a quantity that depends on a time derivative. The software allows only symbolic use of such quantities. Either remove the need to access this quantity or create an internal node, assign the voltage of the internal node to this quantity, and access the voltage of the internal node.
        ERROR (VACOMP-1816): Exiting AHDL compilation.
     e=0.5*(V(y22,gnd)-standard);
    x=ddt(V(y22,gnd));
    if(x==0)begin
    if(e>0)
    A11=A11-eatah;
    else if(e<0)
    A11=A11+eatah;
    end
     Could you please expalin more how to solve this error.
    You didn't give the error, but a guess is that the problem is the assignment to a variable.
    Rather than assigning the result of the ddt to a variable, better to use a contribution statement. So:
    electrical x;
    analog begin
      V(x) <+ ddt(y22,gnd);
      if(abs(V(x))<1e-5 begin
    Note that you should never do an == on a floating point number in any language, but particularly in a circuit simulator you might have a number that is numerically very close to zero, but not precisely zero. So as you can see I'm seeing if it is close to zero rather than using ==.
  • Sali
     Thank you for your help.
    It works with me now, but the question is can I use ddt and ddx to model the differential equation? I'm asking this question because ddt gave me unexpected result, I use it to test when the curve reached the stable point (becames fixed to a certain value for the rest of the simulation) so I expected the ddt to be changing until becomes zero when the curve becomes stable but it always gives me 3 althogh the curve is stable after a certain period of time?
    and is there a way to build a model in Cadence using a high level language liek C++?
    Thanks again
  • Sali
     Waiting for any feedback please?
  • Tawna
    Tawna over 12 years ago
    If you would like immediate feedback, please contact Customer Support at http://support.cadence.com .
    The folks who answer questions on this forum do it "outside of their day job".
    best regards,
    Tawna
