  3. PVS - Cadence Physical Verification System
  • Views 2768
Kovinko
Kovinko over 12 years ago
Hi all,
Please can you give us the advice how can we integrate PVS into virtuoso environment?  We install it, but PVS menu dont appear in virtuoso layout menu. Does it some variables setting? thank a lot
Martin
    Hi Martin,
    All I have us <PVSinstDir>/bin or <PVEinstDir>/bin in my UNIX path (so I can type "which pvs" and it returns the pvs executable). No special environment variables needed.
    Then (if in IC616) I use Launch->Plugins->PVS (in the layout window) to add the PVS menus. In IC615 it's  Launch->PVS.
    Which IC version are you using (Help->About in the CIW, and which PVS version (type "pvs -version" in a UNIX window)?
