  3. APS:Command line: Multi-Processing
  • Views 2231
Ionutz
Ionutz over 12 years ago
I am running simulations using the APS from command line as shown below whereby the “mt=2” it initializes the multi-threading capability:
aps +spice aps.sp +escchars +log aps.log -raw ./psf +aps=moderate +mt=2
Is there a similar keyword that can be used from command line or Spectre options within Spice netlist for Multi-Processing?
The purpose will be to use something like “-mp=3” when user has ALTER statements within netlist (or Monte Carlo) and to have the simulator run the 3 jobs in parallel instead of sequence.
Thank U,
Ionut
    There is no support running separate alter blocks in parallel (yet). Please contact customer support.
