  3. ABSTRACT GENERATOR : absSelectCell for a multi-cells Library...
  • Views 15098
ABSTRACT GENERATOR : absSelectCell for a multi-cells Library, syntax ?
samung
samung over 12 years ago
I would like to know what is the syntax for the cells selection, to generate the ABSTRACT views and LEF file for a multi-cells library. let's say : cellA, cellB, cellC.
I have in my abstract.record :
absSkillMode()
absSetLibrary("library_name_xxxx")
absAttachTechLib("tech_file_name_xxx")
absSelectCell(".............")  <= line under investigation
absDisableUpdate()
absSetBinOption("Core" "PinsPowerNames" "vdd")
absSetBinOption("Core" "PinsGroundNames" "vss")
absSetBinOption("Core" "PinsOutputNames" "Q QN")
absSetBinOption("Core" "PinsClockNames" "")
absSetBinOption("Core" "PinsAnalogNames" "")
absSetBinOption("Core" "ExcludeExistingTerminals" "")
absSetBinOption("Core" "PinsBoundaryCreate" "off")
absEnableUpdate()
absPins()
absDisableUpdate()
absSetBinOption("Core" "ExtractSig" "false")
1/ attempt FAILS :
conf_file :
set cells_list "cellA cellB cellC"
abstract_batch.log :
REPLAY    (ABS-1429): 5  absSelectCell("cellA cellB cellC")
ERROR     (ABS-1308): Failed to open the cellA cellB cellC cell because either the cell does not exist or you are using an options or replay file from another library and the cell does not exist in the destination library. Ensure that the cell exists and then try again.
2/ attempt 2 FAILS :
conf_file :
REPLAY    (ABS-1429): 5  absSelectCell("cellA cellB cellC" "cellA cellB cellC")
*Error* absSelectCell: too many arguments (1 expected, 2 given) - ("cellA cellB cellC" "cellA cellB cellC")
I don't have the ABS-1429 details in my doc....
Thanks a lot !
P.
PS : tool version : IC6.1.5-64b.500.9
  • ColinSutlieff
    ColinSutlieff over 12 years ago
    absSelectCell is for a single selection.
    You need:
    absSelectCellsInList(" cellA cellB cellC")
    Colin
  • samung
    Thanks, it works fine !!
    P.
